440 Piston available for (almost) free
Since I upgraded my Scram 440 to 500cc I have one perfectly run in 440 piston left over, only 5k km on it.
@Dool mentioned somewhere here that you only need to bore out the Hima cylinder (and hone it) which should be cheap.
The stock ECU will be running this relatively small displacement increment without problem (as it does in my 440 -> 500 conversion).
I will charge you packing and shipping, the piston (complete with rings etc.) is free.
PM me if interested.
Design of the crown is dissimilar to LS410 but I wouldn't worry, keep us informed as to the outcome.
I'll send the 443 map when I can.
I found that the Valve for 440 is also a different part number than Himalayan 411.
