750 Himalayan 2027 release
The upcoming Himalayan 750 engine is essentially an "evolution" of the current 650cc parallel-twin, but it has been specifically re-engineered to suit long-distance touring and off-road grunt.
Here is how the performance of the Himalayan 750 (based on prototype data and testing reports) compares to the current Interceptor 650:
Engine & Performance Comparison
| Feature | Interceptor 650 (Current) | Himalayan 750 (Expected) |
| Displacement | 648cc | ~750cc |
| Cooling | Air-Oil Cooled | Air-Oil Cooled (Enhanced) |
| Max Power | 47.4 PS @ 7,250 rpm | ~55–60 PS |
| Max Torque | 52.3 Nm @ 5,150 rpm | ~60–65 Nm |
| Throttle Type | Mechanical Cable | Ride-by-Wire |
| Braking (Front) | Single 320mm Disc | Dual Disc Setup |
3 Major Differences You'll Feel
1. More "Low-End" Torque
While the Interceptor 650 is a smooth, high-revving roadster, the 750cc engine is being "bored out" to provide more torque at lower RPMs. This is crucial for an Adventure (ADV) bike, allowing you to climb steep trails or overtake on the highway without constantly downshifting.
2. Ride-by-Wire & Ride Modes
Unlike the Interceptor’s traditional cable throttle, the Himalayan 750 features Ride-by-Wire. This allows for:
* Switchable Ride Modes: You can likely toggle between Performance (full power) and Eco/Rain (gentle power delivery).
* Traction Control: The 750 will likely be the first RE twin to feature electronic traction control.
3. Better Heat Management & Refinement
One common complaint with the Interceptor 650 is the heat felt on the legs in heavy traffic. The Himalayan 750 prototype features an upgraded oil-cooling system and revised engine casings to help dissipate heat more effectively, which is essential for a bike meant to travel across diverse terrains.
The "Dual Disc" Advantage
Because the 750 will be faster and slightly heavier, Royal Enfield has added dual disc brakes at the front (as seen on the EICMA prototype). This provides significantly more stopping power and better "feel" compared to the single disc on the Interceptor 650.
Would you like me to find out more about the expected suspension travel or seat height for the 750?
There is 865cc bbk that has been around for some time. RE could give life to another set of bikes with the same engine platform now in the 800cc range :LOL:
I will definitely test drive this one, while I am overall happy with the 440 and expect some add. power once upgraded to 477 the missing power at takeover compared to the Guerrilla is felt. the 750 wont have that problem. of course it all depends on overall ease of riding, e.g. seat height and weight to slash around. we'll see.
AI generated?
The twin cylinder Himalayan is supposedly what the market was asking for, from the onset of the 411 people have whined and moaned about putting a 650 engine into it.
So now that it is coming I wonder how popular it will be, Harley Davidson make adventure bikes also as does BMW, try picking one up when the inevitable happens.
But the 650's are Lams approved ie low power to weight ratio making them supposedly safer for novices, will the new Himalayan be supplied likewise.
Well according to AI from Google, regardin a pudding question "you must test something to know its worth".
I'd we are going to make AI generated Posts then perhaps a disclaimer should be included.
Not having or wishing to have an Account with what was Twitter before an extremely unreliable source of truth bought it and changed its name to X, I and hopfully many others dont have access to Grok.
Whow, AI figured out what I mean by pudding question? I consider that near human... LOL.
In any case, if one uses ones discernment while using AI, it's mostly useful. And if not one will be fucked just as bad by human manipulation.
Back to topic pls. I will be using AI when I deem it useful, from wording and formatting it should be obvious but if you insist I will add a disclaimer 😍😜
The " proof of the pudding is in the eating"
I knew that long before I heard of AI :)
So I also await your thoughts when you get to ride the new Himma Beast .
