Well in all fairness I do have a racing ECU programmer here on the standby, so if plug n play fails I will have to make my own setting for the scram 477 !
So why not reprogram the original?Well in all fairness I do have a racing ECU programmer here on the standby, so if plug n play fails I will have to make my own setting for the scram 477 !
www.instagram.com
That's what my friend will do. Reprogram the original in case I cannot do with the 440/fuel x combo out of the box.So why not reprogram the original?
They are a small business in Navi Mumbai, with a dynojet rolling road. I would suggest your negative response was a direct result of how you questioned their set up.There seemingly is one in India as well, however they are not a business, my guess is "rich parents kids", when I asked them why they did not have a proper webpage or contact number or anything resembling a business they reacted with "fuck off - we are not a business"
so I dont know what to do with them. maybe one of you guys want to try
Login • Instagram
Welcome back to Instagram. Sign in to check out what your friends, family & interests have been capturing & sharing around the world.www.instagram.com
Save yourself some money and get your friend to reprogramme the original ECU. Following that your friend would have a potential business re flashing a lot of himalayan ECUs. That would be a win win situation for you and him.That's what my friend will do. Reprogram the original in case I cannot do with the 440/fuel x combo out of the box.
too late, and no backsisSave yourself some money
do your inquiry into the rich kids and let us know.
Well hopefully I can get some dialogue going with the boys in Navi Mumbai and take it from thereA word about ECU re programing: the flash part is easy, basically it is an EPROM and tools to flash those are cheap and easy to use. Each RE dealer has one to apply updates of ECUs.
The tricky part is the program that allows to make the data set for the respective ECU. There seems to be no norm for the memory allocation and data placing from company to company so only if 2 bike brands use the same ECU manufacturer the same tool could possibly be used. But even that is not a certainty as not all vehicles use all sensor data in the same way or even have access to the same data/sensors.
There is one company in Italy and one in Canada I know of who do RE ECU re programing and both charge in the ballpark of 500 bucks for an update. I do not know if they use the same programing tool RE uses (in their factory) or if it is a clone or something else entirely. But it aint cheap.
Ask if they take fruit or veggies as collateral, not being a business I mean ...Will keep posted.
Yeah, for a company thats not a business they do have a dynojet 250i, and their dyno slots are booked up for a month in advance. Their business is sports bike ECU remapping and Dyno tuning sports bikes and drag bikes, they sell exchange sport bike ECUs around the world. They have confirmed that they have never reprogrammed a Himalayan but are confident they could crack my BS4 ECU with a month plus some dyno time and a lot of money. Interestingly they did say from experience with various other Royal Enfields, the very limited tuning ability of the Powertronic piggy back ECU severely limits what can be achieved, primarily because they can essentially only deal with spark,ignition and fuel ratio, they say the ability to change O2, Lambda & certain aspects of fuelling in conjunction with the primary items makes a big difference. I did share a screenshot of the 'Red Box' tuning software, they basically said it was also very limited just like the Powertronic. Dont shoot the messenger, just repeating what I have been told.Ask if they take fruit or veggies as collateral, not being a business I mean ...
spoiled rich kids, not happy with critique of any kind and - idiots to boot.I wonder why they told you to Fuck off?.
additional questioning revealed that Hima and Scram 411 also use Keihin - but no model specifics where known.Bosch does not manufacture the Engine Control Units (ECUs) for Royal Enfield's single-cylinder motorcycles, such as the Meteor 350, Classic 350, and Hunter 350. These models utilize ECUs produced by Keihin, a subsidiary of Honda, which specializes in fuel injection systems for motorcycles. The Meteor 350, for instance, employs a Keihin ECU that manages engine functions like fuel injection and ignition timing. This collaboration with Keihin reflects Royal Enfield's commitment to modernizing its small-displacement motorcycles with advanced electronic systems.
In contrast, Bosch supplies ECUs for Royal Enfield's larger, twin-cylinder models, such as the Interceptor 650 and Continental GT 650. These motorcycles are equipped with Bosch's ME17.9.71 ECU, which is designed to handle the more complex engine management requirements of higher-displacement engines.
I think that because I know that. The red box may have been initially made for Honda models but it was not the OEM ECU, it was meant for tuning outside of the OEM ECU which even Honda does not make public. You see that it does not use the close loop mode because each and every small increment of rpm was meant to be optimized on a dyno - which is normal in a racing environment but not in regular street use.it is not a racing ecu, why would you think that?
Yes your right it has drifted off topic. Its really about assumptions that a 440 scram combined ECU and Throttle Body will actually be better than the prior 411 equivalent with a Fuel X pro + fitted.In any case, that discussion is now closed here - we are getting off topic </moderator hat off>
