If you want to download our maps for this ECU please contact me via PM, thank you!
The ECU/Maps/Software discussion is HERE.
How to properly swap maps on the RED BOX
This is the BS4 ECU that replaces the stock ECU (not a piggyback).The software (same as on the CD) is here (click to download)
UPDATE: software now comes on USB stick but it is the same version
The software runs on all modern Windows OS - from XP (and probably even Win 2000 if you add usb support) to Win11.
The default maps that come with this ECU are as follows: as of the manufacturer they are meant for:
Map1: 500cc lean (can be used for 477)
Map2: 500cc rich (can be used for 477)
Map3: Stock 411: 5% leaner (high elevation setting)
Map4: Stock 411: 5% richer
These maps are not even close to being as optimized as ours so swap them as soon as possible.
